brianjrealto
Well-Known Member
Hi all,
My speakers are in need of the L-pads needing a good cleaning. The sound is a bit scratchy when rotating the Brilliance control on both.
Luckily, the L-pads on my ESS Monitors have the ported air vents on the back of the L-pad itself. After spraying into the ports to clean them with DeOxit fader lube, is there anything I can use long-lasting to cover up those vented ports after the cleaning to prevent future dust from getting inside the L-pads? Or, is it a bad idea to cover those vented ports?
