ChaunceyDog
New Member
Hi All. First post, looking for some advice! I've been working on bringing back to life a Lafayette LR1500TA Receiver and it's been going well. However, I'm having some issues with the FM tuner (and maybe the AM as well). As I tune across the band, the signal meter shows good deflection for FM stations, but the audio coming out of the tuner board (even before getting to the tone and amp sections) is low. Interestingly, the audio is loudest just as I tune close to a station. However, the more centered the tuning and the more deflection the signal strength meter shows, the more the audio level of the station goes down until it completely disappears when signal strength is highest. The Lafayette has some unique tuning circuitry (new to me anyway) including a thing called AcriTune. It's supposed to light when stations are perfectly tuned, but its lamp is always lit, whether a station is tuned or not. Just wondering if anyone has any experience with this model who could offer suggestions as to where the issue might be. I've checked all the transistors and diodes in circuit with a meter and they seem ok. Audio is available at the FM discriminator output, but exhibits the same issue of fading away audio as the signal gets stronger, so I'm assuming the issue is somewhere before the discriminator output (pin 14) and after the IF section that feeds the tuning meter. I've attached the schematic and a picture of the tuner board in question. Thanks for any help or guidance you might be able to provide.
