I switched my system on yesterday and found that one of the meters on my 2205 is indicating much lower wattage than the other. The output to each channel seems clean, equal and normal, but the meter is reading almost exactly 1/100th the output. So 20wpc is showing on one meter and .02 is showing on the other.
I worked the channel volume controls through their range of motion about 50 times each (there was a little static which went away quickly) and did the same with the meter selector switch. The reduced indication followed to each setting. I ran the amp and closely monitored it for about 6 hours and its performance never changed. The output remained clean and the one meter's function remained impaired. My system has seen a lot of daily use this week and there were no problems before I powered on yesterday. I saw some other meter issues by doing a search, but nothing quite like this. Has anyone else experienced this? Audio Classics is a 3.5 hour drive each way and I would hate to make that drive for something simple. TIA!
