SkyChurch
The Seeker
Hey, My Marantz 2270's left channel has been cutting out for quite awhile now. Maybe ~10 months or so. It could always be temporarily cured (about 40 minutes, then acts up again) by just cranking the volume way up real quick and then bringing it back to the previous volume, but I'm getting sick of doing that and just want to fix it permanently. What happens is I'll be listening to music or something, and it happens in both aux and fm, and after about 20-40 minutes the left channel will start breaking up and it sounds like static and then breaks out and then comes in staticy and breaks out and comes in staticy etc.
My question is what should I do now to isolate the problem? Or should I just assume it's the output transistors and just replace those, or should I go through it with a signal tracer? Possibly the relay?
If you think I need to go through it with a signal tracer then I'll have to buy one. Anyone have any recommendations? I've heard that you don't need to spend any more than 25 dollars on an ST, but the cheapest one I could find on froogle is like 50-60 dollars I think. If you could send me a link to a good cheap one I'd really appreciate it.
As always all advice is appreciated, thank you!
Andrew
Andrew
