Phil lewis
New Member
Hi.
I just recapped a Marntz 2325. Everything is working great except that in FM mode the left side volume is very low compared to the right side. Here are the specs of the issue:
*The Dolby levels controls will compensate when using Dolby
*The issue occurs only on FM. The other modes work perfectly including AM
*When switching the "Mode" knob to reverse, the issue follows to the other side ie the rt side is lower
*When the "Mode" knob is set to mono both sides are equal & @ the proper volume
Do you think I have an adjustment problem or component issue?
This is my first rebuild. I basically started this project with good soldering skills & a limited knowledge base of electronics so please be patient with me.
Thanks in advance for your help,
Phil
Phil
