Thinker
Super Member
Hi Everyone,
I recently picked up a cheap Lepai 2020TI to mess around with. I connected to my bench equipment since I was curious to see if it would meet spec. I connected it to my Variac set to 120 volts, my HP8903B audio analyzer, and my 8 ohm 1% non inductive dummy load. I've tested a bunch of equipment before never with an issue.
When I tried sending a 1.2 volt 1 KHz signal to the Lepai with the tone controls out of signal path I got nothing out of it and I noticed the the Lepai's LED's were periodically dimming. I played around with different input voltages and I would start each time with the volume all the way down and then bring it up slowly and I would get no usable signal according to the analyzer. So I connected my scope to see if I anything was coming out. All I saw was a flat line that was periodically going up and down but staying flat.
I discovered that there was -5.68 voltage present on the chassis when in reference to ground. When I disconnected the dummy load it disappeared. When I measured the connections to the dummy load in reference to ground there's no negative voltage, when I connect the dummy load but disconnect the BNC between the dummy load and the analyzer the -5.68 volts disappears. I then measured the BNC connection on the front of the analyzer in reference to ground and there was no negative voltage.
I discovered if I send a 1 KHz tone into the Lepai using my ipad instead of the audio analyzer, I get a normal test wave at the output that meets spec, I'm guessing that there's some kind of grounding problem in my testing setup but, I don't understand why it hasn't been a problem in the past. That or something isn't right in the Lepai.
Side note, I've always noticed when testing gear at it's rated spec you hear some of the test tones coming from the gear. I played music through the Lepai into the dummy load, without clipping and was surprised how much of the music I could hear coming out of the Lepai, it sounded like tinny headphones, I'm guessing that the sound was coming from the small inductors on the ouput? Just curious what causes that.
