1ns/div 10mV/div into 50ohm. Pulser is a 125ps tunnel diode.View media item 15052
What are you showing us? How your scope works?1ns/div 10mV/div into 50ohm. Pulser is a 125ps tunnel diode.View media item 15052
This TD is the fastest rise i have AND it requires a 100V pulse so that kind of sucks. I would love to see some pictures of your stuff.Ah, you're asking for the rise time of the scope. I thought you were seeking pictures of fast rise times of circuits, not the scope's limitations. I guess I could use the TDR output of my HP 54120 scope, which should have a 30ps rise time, and feed that into another slower scope to see what I get. May take a while to get a picture, but sounds like fun.
You figured wrong. You are using an obscure example that most people can't conduct.No. Im showing you the rise time of a 485 oscilloscope when fed a high amplitude pulse coupled with a tunnel diode. Do you have some pictures of the rise time of your scope to share? I figured since there are a lot of scope experts here,there would be plenty of pictures of their calibration and testing. My bad.
I'm sorry. I'll try to do better next time.You figured wrong. You are using an obscure example that most people can't conduct.
I know the Tektronix type 109 pulse generator uses a mercury reed switch. The downside to them is they have a very limited life and are filled with mercury.OK, I guess this means the pressure is off and I don't have to devise some method to take a looksee at the scope's rise time? I await your next DIY challenge!
All seriousness aside, a long time ago (early 80s) we used a mercury wetted reed relay to generate sharp edges when looking at rise time of the old LH0033 and LH0063 Fast and Damn Fast buffers. I think the name was later changed to Ultra Fast instead of Damn Fast. At any rate, the mercury wetted aspect made it so the relay contacts didn't bounce and it actually produced a really sharp edge.
I've been a dentist for 37 years. The first half of that, I used mercury every day. I'm probably full of mercury and so far, I don't see any.......uh.....any.......um, what were we talking about?You, too, would have a very limited life if you were filled with mercury.
