Lets talk About DACS
Discussion in 'DACs' started by Cylontymany, Apr 4, 2017.
  1. Cylontymany
    Cylontymany Well-Known Member
    914
    Portland,Oregon
    I am presently using my headphone jack on the back of my mac to my vintage receiver but I would like to maybe go the dac route to improve the sound. Are there some good budget dacs $100-300 range?
  2. crazy-in-az
    crazy-in-az All humans are vermin... Subscriber
    3,012
    Kingman, Arizona
    People seem to really like Schiit. I have no experience with them, but they get great reviews and they have four DACs ranging from $99 to $2299!
  3. rifftrax
    rifftrax mix-meister
    2,798
    Medford, OR
  4. botrytis
    29,502
    PODUNC USA......
    Well, iFi Nano - under 300 USD. USB compatible and no drivers needed for Mac or Linux.
  5. Finjima
    Finjima Well-Known Member
    589
    Lake Helen Florida
    Look up the Multi-bit Dacs by Schitt, they found a new way to dac from the delta-sigs chips. also there is a sub forum here called DACS (4 sub forums down from this one) where your question plus more as talked about there on a daily basis. there are several threads on the Schitt dacs there you can read through and if you need more head over to Head-fi and there is a ton more material there, Plus a book by the founder Jason, good read
    stish and cratz2 like this.
  6. botrytis
    29,502
    PODUNC USA......
    The iFi will do up to 768/24 bit files and 1X to 2X DSD files, natively.
  7. arclight73
    arclight73 Addicted Member
    6,020
    You could look at the Maverick Audio D2 which would offer you a tube output for 315 shipped with all upgrades. I recently picked one up and its pretty impressive. Especially for 300.
    3l3ctron and Me Tarzan like this.
  8. a10warthog
    a10warthog Member
    96
    I have a Schiit Modi 2 Uber ($150)and a little NuForce $(179). Both work great for me. If you don't get the "Uber" upgrade with the Modi 2 it's $99, and still sounds great, at least to my ears. I had a little NuForce Udac3 ($99) that worked really well until it was stolen.
  9. unfairlane
    unfairlane Well-Known Member
    523
    Norway
    Get one of these. A wery good dac and then so many thing moore. Jack out in the rear
    https://www.amazon.com/Behringer-DEQ2496-BEHRINGER-ULTRACURVE-PRO/dp/B000CCN152
  10. botrytis
    29,502
    PODUNC USA......
    The Behringers are OK, nothing great though. I had one and went iFi because the Behringers are totally mass produced.
    stish and mjw757 like this.
  11. Cylontymany
    914
    Portland,Oregon
    I just use my itunes library for my music-The Maverick Audio D2 looks nice! Any thought any more suggestions?
  12. GSS61
    GSS61 Super Member
    1,624
    Tallahassee
    That Maverick D2 does look great - don't think you can go wrong with that
    I recently got a NuPrime Audio uDSD from Sonic Unity and I really like the sound of it. I run it through a separate tube pre-amp to sweeten things up a bit.
    24-bit/384kHz, native DSD 256, very well made, excellent specs, small, no external power supply (powered by the USB), reasonably priced, works with Windows and Mac OS, etc.
    $179... plus, they are offering a $50 rebate if you send them a used DAC in any condition
    https://sonicunity.com/collections/dac/products/udsd
  13. Cylontymany
    914
    Portland,Oregon
    Thanxs-I will check this out too! I just want a DAC I can just plug in and dont look back staying below $300 The maverick Audio D2 still sounds nice but I dont really want to get into all the "Upgrade Thing" Please dont get me started-I will research it out to death and I am tired of doing that anymore...
  14. AlTinkster92
    AlTinkster92 AK Subscriber Subscriber
    3,345
    NC
    Heck I'm the cheap one, I use a Aune T-1 with a 6922 tube, works fine for me and only 150 bucks, its 3 years old now.
  15. marysdad
    marysdad Member
    75
    No. California
    I use an Objective ODAC for feeding my PC into my SX-950. It's at the same price point as the Shiit Modi. You wouldn't go wrong with either.
  16. Bodyblue
    Bodyblue AK Subscriber Subscriber
    4,062
    CA
    Are you hearing background noise of any kind? If you are not, then you dont need an external DAC. Try and listen to one hooked up to see if you can tell the difference.
  17. Teej
    Teej Active Member
    218
    New Orleans, La
  18. rifftrax
    2,798
    Medford, OR
    Sweet! Let me know how you like it... I'm absolutely loving mine so far. The balanced outputs are a huge plus in my book as well...
  19. Teej
    Teej Active Member
    218
    New Orleans, La
    Dig your screen name!
    So the Korg sounds amazing, but I'm having some trouble. I'm streaming audio through it from a laptop playing mp3's with Media Monkey (I know the Korg is capable of a lot more, but this is how I plan on using it for the most part), and occasionally the audio will suddenly and all at once become very distorted with louds pops and skips that sound a lot like a torn speaker cone. When this happens the song also seems to slow down slightly, playing at maybe 3/4 the proper speed. Each time it's happened I've simply unplug the USB cable from the laptop and plug it back in and everything goes back to normal, but what could be causing this?
    I installed all the necessary drivers as I was planning on sticking with Media Monkey as my primary playback software, but I did install the Audiogate software.
  20. gvl
    gvl Super Member
    1,109
    Try a different USB cable and/or port for starters.
