Let's talk preamp kits
Discussion in 'Tube Audio' started by airtime, Oct 7, 2017.
  1. airtime
    airtime Super Member
    2,088
    Central Arizona
    I mainly use a Conrad Johnson Classic 2SE that I love. So this post isn't about "going up a level" but more like something else to try and play with.
    I was thinking a cheap preamp kit to add more tube like sound. Ok, let's not get into what the tube sound is. The CJ is EXTREMELY transparent and adds nor takes away anything - it does what a preamp should - preamp and burffer.
    What kits would you recommend in the $500 range.
    A kit using mainly the 12axt, no tone controls, simple, no 12AU7 or 6922, something that puts more "warmth" back into the equation.
    I would use this mainly for my newer gear like a NAD C275BEE. Which gives me listening fatigue after 20 minutes.
  2. petercapo
    petercapo AK Subscriber Subscriber
    721
    One tube preamp kit that comes to mind in that price range is the Transcendent Sound Grounded Grid preamp. Unfortunately, by all accounts it would not be very likely to meet your sonic criteria. Why don't you want 12AU7? From what I have read, 12AU7 has a syrupy, tubey quality.
    Transcendent Sound has another preamp kit for a little more that uses 300B.
    There is also this: https://www.tubedepot.com/products/elekit-tu-8500-stereo-tube-preamplifier-kit
    You might also have a look at the Little Bear kits on ebay and Amazon.
    The tubes4hifi SP9 is around $750 for the kit, I believe.
    You might find Analog Metric an interesting place to browse: http://www.analogmetric.com/
    Analog Metric seems to have preamp kits: http://www.analogmetric.com/categor...0&price_min=0&price_max=0&filter_attr=&page=1
    There is also this: http://diyaudioprojects.com/Tubes/tubes.htm
    Edited for spelling.
  3. superjojo
    superjojo Active Member
    225
    If you cant listen to it, why don't you sell it?
  4. petercapo
    721
  5. kward
    kward AK Subscriber Subscriber
    3,113
    Utah
    Hmm. Not a full kit, but there's the Aikido octal preamp board.
    Lavane likes this.
  6. BillWojo
    BillWojo AK Subscriber Subscriber
    2,270
    Burlington, NJ
    Tubes4hifi, I have the SP9 kit. If you do your own chassis you can get the board kit for a lot cheaper.
    Responds well to tube rolling and was a major upgrade to my system. Playing familiar music I hear details that I never knew where there.
    I have a Aikido Octal tube kit that I'm collecting parts for. I found a great deal on the SP9 and this got shelved. Maybe this winter I'll finish it and compare.
    Both the SP9 and the Aikido Octal have been compared to preamp's that cost in the 3 to 5K range. Great designs without the designer signature. Although both designers of the mentioned preamp's rate very highly in my book.
    BillWojo
    Lavane likes this.
  7. mcdan
    mcdan Well-Known Member
    569
    North of Detroit
  8. gadget73
    33,949
    Southern NJ
    Bottlehead stuff also might fit the bill, though they run 12au7 tubes. I have one sitting here that I fixed. Sounds nice, not super tubey though if thats what you're after.
  9. Lavane
    6,150
    northern cal.
    Ive been using an Aikido preamp using RCA 12au7 clear tops and like it. I should try the octal version at some point. There is a clarity to this design that I really like.
  10. nerdorama
    nerdorama AK member Subscriber
    2,242
    Seattle area
    A friend built an octal Aikido. It's very good sounding. Not sure I'd call it tubey in the traditional sense.
  11. crispycircuit
    crispycircuit AK Subscriber Subscriber
    1,187
    near Buffalo NY
    A PAS 2 or 3 has plenty of tube mojo. Do you need a phono stage?
  12. gadget73
    33,949
    Southern NJ
    PAS2 in relatively stock form may not happily drive a solid state amp though.
  13. petercapo
    721
    I didn’t mention the PAS in my list, because I’ve had the sense that airtime has sworn off it. Still, the description of what he seeks in post #1 does sound like a pretty good description of the PAS...
    With the tone controls bypassed, it may be able to do it. It would need some study: http://www.audioregenesis.com/documents/PAS Compatibility Issues.pdf
  14. crispycircuit
    1,187
    near Buffalo NY
    Yes, I would recommend changing the input resistors on any solid state amps to better match the high impedance. Or a tube buffer. But not to many people would use a solid state amp with a PAS. The company Sound Values that took over the Dynaco name & inventory had sold preamps like you want. Retrovert has one. They got very good reviews and show up used, would also be easy to swap parts, I think it has a cathode follower for low impedance. Maybe PAS boards with a tube buffer board for your own custom kit. In Audio Amature there was a great remake of the PAS circuit with a buffer and B+ regulator. Vorhis mod could be hand wired in to your custom chassis. All depends on how time and effort is available. This stuff can take over your life.
    drtool likes this.
  15. airtime
    2,088
    Central Arizona
    I'm leaning towards a Bottlehead or a full PAS kit. Again, the purpose of this is to tinker. I'm not looking for the ultimate preamp.
    Bottlehead's middle name is tinker and the PAS is the most worked on preamp in history. But don't worry I'm not buying a vintage PAS. Only the kits and parts and build my own chassis. So around the holidays I'll decide between the two.
  16. Paully
    Paully AK Subscriber Subscriber
    233
    Alabama
    Bottlehead seems a lot less about tinkering than it used to. Their products, which I still buy and use, are certainly subject to parts upgrades and and maybe putting a choke in the power supply and that sort of thing so there is some level of tinkering. But their lines are much more developed than they used to be when people were installing filters, regulated power supplies, dual power supplies, etc... etc... A lot of the best stuff is already incorporated. I would still recommend them to anyone but I just don't get the hardcore tinkering vibe from the Foreplay I days anymore.
  17. airtime
    2,088
    Central Arizona
    I had a Foreplay WAY back in the day. I nick named it "the humming bastard". Never got that thing to stop humming.
  18. Paully
    233
    Alabama
    Yea, I remember some posts along those lines... I had a FPII that buzzed like a hive but we managed to fix the problem, I think with a reverse recovery spike filter or some odd name like that (speaking of tinkering). My FPIII was trouble free and my Bee Pree is an astounding preamp. I love it and honestly never even think about upgrading it.
  19. sfox52
    sfox52 AK Subscriber Subscriber
    3,576
    Maryland
    I still use a basic FP II and love it.
    Paully likes this.
  20. Paully
    233
    Alabama
    I still have a heavily modified FPII and don't really plan on selling it.
