I'm using all separate amps and an external card from the computer (mains, center and rear).
Using both the high level and lfe on the sub, so if I adjust the volume at that point it controls both. I've got the level way up on the card and much lower on each of the other outputs 5.1 . Just curious if lfe should technically be the same volume when going through levels by ear ? I don't want the high level input to be to much on music.
