I must be, but think I'm normal I just plug it in every night with a very positive click. I never even un-wrap my newer cables that came with phones and the one I mainly use isn't even white any more, it's dirty yellowy brown4-2-7, you must be kind to your connectors, which is admirable. Most people are less kind.
Apple introduced that lightning connector in 2012 (had to look it up on Wikipedia, I thought, time does fly, but am I THAT old fashioned ? I still use the 30-pin cable with my iPhone 4s .... )I have working lightning cables that I'v used every day plugging phones in and out of for at least 7+ years
Not my experience at all. I have Apple cables and Amazon cables - have them at work, in my car, on a dual beside charger and around my computer.I have USB cables that are 10+ years old none of my Lightning cables that are working are over 2 years old. Anker and Amazon Basic are the best.....but
Well when the iPhone 5 came out I bought it that first month (I think 10/2012?), that's the cable I'm still using. I bought the iPad 3 just before that also with the 30 pin and thats still in use also.Apple introduced that lightning connector in 2012 (had to look it up on Wikipedia, I thought, time does fly, but am I THAT old fashioned ? I still use the 30-pin cable with my iPhone 4s .... )
Same here. Both (me and wife) original lightning cables have been doing duty since Sept. 2014 and are in fine shape.I've misplaced a couple Lightning cables but have yet to need to replace them due to malfunction/damage. Still have the working original from my 5s.
Remember what Dad always told you...pull the plug by the plug, not by the cord.
Me wonders how and why they are stressing the cable so much.Most people are less kind.
I bought this exact cable from Anker to put in my Jeep for CarPlay and it had all kinds of issues dropping the signal. It works fine for charging, but I had to go back to Amazon's lightning cable for my CarPlay setup. That being said, the only lighting cable I have ever needed to replace was an Amazon Basics cable. It got a lot of abuse being plugged in and unplugged at work. I keep meaning to get a dock for work, but I just have the iPhone laying on my radio and no way to charge it. Not a big deal, since I never get below 40 percent during the day anyway.I have cables that look perfect but for no apparent reason fail apparently the chip in the Lightning plug end fails. The Apple cables are horrible they simply fall apart. The longest lasting cables I have are a couple of 4-inch cables that I use with my Anker charging batteries. They are a couple of years old. I only purchase Anker cables, and Amazon Basics which I think are made by Anker. The Anker Powrline cable is cheaper then Apple cables as so much better construction wise. Restorer John If you haven't tried the Anker Cables get a couple and see how they work out they are much cheaper the Apple cables.
I should point out I have Anker USB Mini and Micro cables that are over 5 years old. The only time I have lost one of these cables is from physical damage.
I only have problems if the socket fills up with pocket lint and doesn’t allow the connector to seat all the way.
I think this is a big part of it.I think part of the problem is the cases we put our iPhones in. On the cables on use with my iPad which these days does not leave my desk, I don't have a problem. But my iPhones in their Otterbox Defender cases are something of a problem the small lighting plug end fits deeply into the case and it is hard to get fingers on just the hard part of the plug. The latest batch of Anker cables is working great.
I forgot to mention it, but I have the same experience with 30 pin connectors. Even the one that was used with my wife's old 4s in an Otterbox is still working fine.I never had a problem with any Apple 30-pin connector. But three of four Lightning cables work intermittently or have completely failed. Two of the failed connectors were Apple brand and the third was Insignia. I had some success using DeOxit to clean dirty pins but connectors on iPhone and iPad mini actually feel loose
Roger
