Limiting output level of a CD Player?
Discussion in 'Digital Sources' started by mattstech, Jul 7, 2017.
  1. mattstech
    mattstech New Member
    31
    Calgary, Alberta
    So lately I'm finding that a few of my CD's are recorded so loudly that they cause distortion. I just got a new receiver (Sansui 350) and I find it has trouble with crazy high inputs. The output on my Pioneer PD-T510 is LOUD, much louder in fact than what my cassette deck or computer could output.
    I'll post some pics of the inside later, but is there a potentiometer somewhere inside to adjust the output level?
  2. evoroadster
    evoroadster AK Subscriber Subscriber
    302
    Honolulu, HI
    A variable or fixed output level is one of the reasons I picked up the Sony XA1ES CD player I have. That plus new replacement laser assemblies were still available for purchase.
    tmtomh likes this.
  3. HackWhite
    HackWhite I guess there's worse things to spend money on... Subscriber
    302
    Cape Cod, Massachusetts, USA
    Go on hifi engine, or any other source that you can find the schematic for said CD player on, download it, and look it over and see if there is a potentiometer for an output level adjustment... if there isn't, you're SOL :bigok:
  4. HackWhite
    302
  5. Dennis Gardner
    Dennis Gardner Jazz Nut
    1,213
    The best passive controller that I have used is this little Nano Patch from SM Audio. Very well thought out, great construction. I have used their audio products from Australia for over 10 years as they have some of the most unique solutions for odd problems that I run up against in installations or live gigs. This would require a 1/4" to RCA adapter to go between your CD and amp. Nano_Patch+_hires_1.jpg Nano_Patch+_hires_1.jpg Nano_Patch+_hires_2.jpg
    http://www.smproaudio.com/index.php/en/products/monitor-controllers/nano-patch-plus
    tmtomh, juno and mattstech like this.
  6. botrytis
    Well, your Sansui cannot handle the output from your CD player. Using the variable output of the player will help.
  7. mattstech
    31
    Calgary, Alberta
    Thanks, something like this would probably work!
  8. mattstech
    31
    Calgary, Alberta
    I'm sure, this never happened before on my old Yamaha. It's quite a bit newer and IC driven as opposed to the transistor-based Sansui
    ilusndweller likes this.
  9. botrytis
    Look at the sensitivity, both output of the CD player and input of the receiver. I bet the CD players output max s 2 volt (very common) and the Sansui input is 0.5 - 1 volt. That would cause the issue you are seeing.
    mattstech likes this.
  10. Dennis Gardner
    1,213
    Sometimes mixing modern gear with vintage gear, it is nice to be able to gain match for smoother source switching and less stress to your gears and ears.
  11. N8Nagel
    5,886
    Sterling, VA
    The Pioneer that I picked up at a thrift store earlier this week has a built in attenuator that can be controlled by the front panel buttons.
    Unfortunately, it needs a new laser, so that helps you not at all.
    2 volts sounds right for CD player output.
    You could also use an inline attenuator on your patch cord.
  12. mattstech
    31
    Calgary, Alberta
    That's probably what's causing it. Would a variable resistor like the ones mentioned above be able to reduce this voltage?
  13. jbrainey
    jbrainey It's only inches on the reel-to-reel Subscriber
    3,883
    (GMT-5:00)
    Just to be safe.....you're not using the inputs intended for turntable input(if it is equipped with such) are you?
  14. mattstech
    31
    Calgary, Alberta
    Hahaha nope, I remember doing that with a 90s sony hifi system as a kid because that was the only "input" it seemed to have. All of my equipment is connected to the AUX input through a switchbox. Just to make sure I wasn't missing anything, I plugged the CD player straight into AUX, bypassing the switchbox and I still get the same problem :(
  15. whoaru99
    whoaru99 Epic Member
    39,961
    LoTL
    Input sensitivity is not the maximum permissible, it is the minimum necessary to achieve rated output.
  16. whoaru99
    39,961
    LoTL
    Causes distortion, where, as in at what setting of the Sansui volume control?
  17. mattstech
    31
    Calgary, Alberta
    Doesn't matter at what volume, the distortion stays the same weather it's louder or quieter
  18. sqlsavior
    4,810
    EspaƱola NM
    Then the distortion is on the CD itself. The modern trend in mastering is to compress and peak-limit (read "clip") the signal so that the average level is louder. Television commercials do the same thing, despite there being a law against it now. Read about the "loudness wars" by googling it. The only solution is to avoid CDs mastered this way. Here is a resource to help you do so:
    http://dr.loudness-war.info
    Green is good, red is bad. You need to use the search feature - there's too much info to just browse.
    juno likes this.
  19. juno
    juno Super Member
    1,023
    Pembroke Pines, FL
    My wife has several CDs that are completely unlistenable unless it is in the car. One of them is a Madonna disc from a couple of years ago. I had to turn it down so low it wasnt really worth listening to in the house.
  20. juno
    juno Super Member
    1,023
    Pembroke Pines, FL
    I will be getting onebof these ASAP. Thanks for the link!
