Fusion
Hi everyone...I've been looking at buying what hopefully will be my last amp for a long while and have narrowed it down as follows. It will be a tube integrated. Can't make up my mind so all comments are welcome!
Primaluna Prologue Premium
Icon Audio Stereo 40 mkIII
Cary SLI80 (used)
Line Magnetic 211ia
Icon Audio Stereo 30 SE
The first two are somewhat similar, push pull amps that take many different power tubes (a definite plus as it would be cool to try different types). Autobias on the Primaluna, manual bias on the Icon. With the Icon I prefer the use of 6SN7 and 6SL7 input tubes as I already own these and like them. I don't own any 12AU7 (Primaluna) that I can roll but it's not like it's an expensive tube.
The Cary is similar I suppose, but higher power (80 watts) and runs in Class A (40 watts) when in triode mode. I wonder if it runs the tubes hard by comparison to hit those numbers. Either way, the reviews are very positive and it's been in production a long time so it must be a quality product.
The 211ia, needless to say LM has earned a great rep over the past few years. The sound of my old Audio Space Galaxy 34 was fantastic with my ProAcs and I imagine I could expect about the same here. I have some nice RFT EL34 tubes and I have a bunch of 12AX7 as well. Doesn't look like other power tubes are an option though, which sucks but I do love the EL34 sound so I can live with that. The LM also is likely to ring in at less money than the other amps and seems like a real bargain in comparison.
Finally, the Icon 30 SE is a single ended, class A amp that runs 2 KT150 tubes. This tube seems to get high praise overall and I like the 6SN7 input tube as well. Wouldn't be able to use my EL34 tubes, which is a bummer, but I get single ended class A sound with a useful 18/28 watts of power (triode and ultralinear modes). A better match for my speakers than most other single ended amps.
I am a little bit hesitant about amps like the Icon 40, Cary, and Primaluna, as I've read that amps are optimized to run one kind of power tube, not multiple kinds, and so you are better off running the tube the amp was designed for. Makes me wonder if getting an amp so that one can roll all sorts of different power tubes is looking at it the wrong way. Might be better to just get the amp that'll sound the best with the tubes it was made for.
Cary SLI80 (used)
Line Magnetic 211ia
