RodrigoLanes
New Member
I have been a reader of AudioKarma for a long time, but this is my first post. I'm looking for an amplifier/receiver for mono vinyls. Any help?
Thanks! This is an amazing site!Welcome here!
Thank you very much. I don't have any in mind. I really like to listen to mono vinyls (Beatles, Dylan, Miles Davis), and I have an old Miida amplifier with the mono / stereo option, but it has several problems, I want to change it.Regular stereo amps can play mono records just fine. Is there some special configuration you want to run that precludes the use of a stereo amp?
My bad (I was thinking in spanish -vinilos-). Thank you though!"vinyls"
Seriously tho welcome
"vinyls"
IF the OP wants a mono (integrated) amplifier with built-in MM phono preamp to play mono recordings through a single speaker -- there are some decent choices, albeit vintage ones.
The EICO HF-12 push-pull EL84 integrated amplifier mentioned earlier would be a fine choice. The EICO HF-52 could be an even better choice (if a bit harder to find and more expensive) if one were interested in pre-LP era monaural records (78s), because it has various phono preamp EQ curves built-in for the pre- 1948 Columbia records LP and RIAA EQ curve era (pre-early 1950s). EICO also made an interesting push-pull parallel integrated amplifier called the HF-32 (ca. 30 watts), but these are fairly uncommon.
The HF-52 is a really nice push-pull EL34 amplifier (ca. 50 watts) with variable loudness and a superb output transformer.
Wish I still had mine!
(stock, borrowed image, of course)
Other good (vintage) choices include the Sherwood S-1000and HH Scott "99" -- there are many others from the pre-stereo era from the likes of Grommes, Brook, Bogen, Bell, harman/kardon (and others that are escaping my recall as I type this).
Mono integrated solid state amplifiers are nearly unknown -- although there were/are a bevy of commercial sound reinforcement (mostly "PA" or intercom system) amplifiers from companies like Bogen and Raymey that could be used as mono amps for phono reproduction.
