I just bought a Scott 222B and I would like to know how to check and set the bias on the power tubes. I found a post where Tinkerbell linked to the instructions on the Scott website. Here's what it says.
The Type 222B (also 6BQ5-based) featured an adjustable self-bias design.
To adjust a 222B's bias: place a DC voltmeter across resistor R-201, 1.2k-ohm, located across the preamp filament heater supply. (Note: Remove the bottom plate cover to gain access below the chassis). Adjust the Bias Control (located between the power transformer and electrolytic cap until the meter reads 38.5 volts DC.
So how do I locate R-201, and how do I connect my meter?
Is this telling me to clip my meter on the legs of the resistor? When I bias my Fender Brown Princeton clone, I'm pretty sure I clip my leads between a resistor and ground.
Is the bias control pot for each power tube accessed from the underside of the amp, or top side?
A picture would be worth a million words for me. Thanks for the help.
Onebean
Onebean
