"Loose" McIntosh black rocker switches: can these be tightened or retensioned?
Discussion in 'McIntosh Audio' started by monkboughtlunch, May 6, 2017.
  1. monkboughtlunch
    monkboughtlunch Super Member
    1,810
    Regarding the black vertical rocker switches that McIntosh used on units like: MX-110, C22, MA5100 etc, can these be tightened up if they have become "loose" or the "friction" has dissipated over time?
  2. dewickt
    dewickt Will fix about Anything
    3,394
    Knoxville, TN
    The foam backing has deteriorated on the back side of the rocker, this is what firms up the switch.
    monkboughtlunch likes this.
  3. monkboughtlunch
    1,810
    Thanks Terry! Can the switch be easily repaired with new foam?
  4. dewickt
    3,394
    Knoxville, TN
    The repair is not to hard, its finding the right foam that is hard.
  5. marantzfan
    marantzfan ... Subscriber
    8,058
    Peoria, Arizona
    So, does anyone know which foam is appropriate here? I've got the same situation with my MX110.
    Almost looks like weather stripping closed cell foam pieces...?
  6. monkboughtlunch
    1,810
    I'd like to know as well. Anyone found the correct foam? Paging Terry....
  7. dshoaf
    dshoaf That high voltage buzz
    10,117
    Santa Cruz, CA
    That's what I used - from the Home Despot, too. Difficult to get installed once you pull the backing off the sticky part, tho.
    Be sure to get all the old stuff that's turned to powder out first.
    Cheers,
    David
    monkboughtlunch and Bill Ferris like this.
  8. marantzfan
    8,058
    Peoria, Arizona
    Did you disassemble the switch somehow? Seems very tedious to just get the old foams out without disassembly.
  9. Destructor
    Destructor Super Member
    1,518
    Braintree, Mass
    The rocker switches on the faceplate aren’t switches, they engage slide switches attached to the chassis. Remove the face plate and you have access to the rockers. I removed all the foam from my 110 and my 230, I just live with the loose feel.
  10. jlovda
    3,425
    NE Ohio
    What switch technique did Mac use for the switches on the more recent commemorative edition of the C22 as compared to 50 yr old models like the original C22, MA230, MX110, etc?
  11. monkboughtlunch
    1,810
    Did you take pictures? And can you provide a link or part number for the correct weather stripping product? Thanks!
  12. monkboughtlunch
    1,810
    Hi Terry, what foam do you recommend using?
  13. monkboughtlunch
    1,810
    Bump. Anyone have pics and link to the foam product?
  14. monkboughtlunch
    1,810
    I installed some festoon LEDs in my MX110. Since I've taken the faceplate off, I thought now is a good time to see if I can address the notorious McIntosh foam disintegration issue.
    First off, the foam issue is not just a tactile problem. I'm actually experiencing some static and drop outs from one of the switches. I want to rid it of the rotted crumbling foam before I hit it with DeOxit.
    See photos below. I've heard the mechanism is just a slider switch with a plastic rocker over the top. Is that correct?
    Does anyone know how to remove the plastic rocker cover in order remove all the crumbling foam debris? I'd like to get those rockers off, clean the foam out and they spray some DeOxit or Faderlube on the switches. Then add new foam, reinstall the rocker and button it back up.
    Has anyone tackled this process before? If someone has already developed a process to address this it needs to be a sticky!
  15. monkboughtlunch
    1,810
    More photos.
    Has anyone taken the rocker cover off the switch? If so, what is the process?
    Are the yellow strips shown below the backing for the rotted foam, and if so, can they be pulled out without disassembling the switch? To get new foam in, does the rocker need to be taken apart?
  16. marantzfan
    8,058
    Peoria, Arizona
    This must be a highly guarded secret. I've asked around several times and... Nothing.
    Surely someone knows as I've heard of it being done.
  17. monkboughtlunch
    1,810
    Agreed! The C11, C22, MX110, MA230 and MA5100 all use these same rocker switches. After 50 years, the foam will have disintegrated in every single surviving unit (unless restored) of these models. Given the ubiquity of this crumbling foam problem, there are certainly people who know how to make this repair.
    It's not clear if the pins can be removed to allow the rocker cover to be taken off. It's also not clear if those strips can be pulled out with the rockers in place.
  18. 62caddy
    9,224
    NEPA
    Audio Classics replaced the foam on mine. Check with them for the materials needed.
  19. monkboughtlunch
    1,810
    Thanks for the tip. I'll look into it. In the meantime, if anyone has any experience or tips on how to do this, please post here.
    I wonder if this Frost King material could be custom trimmed and used for the rockers.
  20. monkboughtlunch
    1,810
    Bump. Anyone?
