transformer8
New Member
I want to listen to audio files on either of my four PC metal towers. I discarded the sides on all four of my PC towers because they aren't necessary. I use either a Radio Shack MPA-250B 250 watt amplifier or a Radio Shack PA amplifier 40 watt and either a set of Pioneer bookshelf speakers or a set of Polk Audio bookshelf speakers. The problem is that there sometimes is a loud buzzing sound that completely disappears when the PC is shut down. The PC towers are placed on a 24" wide NSF shelf with 3/8" sheets of HDPE used to create a smooth surface to place the towers on. The four towers are placed very close to each other with just inches separating all four. I use the top tower that is nearest to my person and I get a very loud buzz on either set of speakers using either amplifier and using either one red and one black 22AWG solid or the Radio Shack brand speaker hook up wire that is sold as paired strands with the white stripe for orientation. The power outlet is a Belkin all metal ten plug power tap with ground. The same buzzing is identicle on either amplifier and on either set of conductors aka wires and on either set of speakers. I disconnected the Radio Shack TRS audio cable from the PC tower to either amplifier and the buzz continued in identical pitch and volume. When I turned the PC tower off the buzz disappeared. However, having shut off the PC tower nearest me and turning on my PC tower that sits on the bottom shelf and is blocked by my PC tower that I do not use there was no buzzing sound on the speakers. In summation, the PC tower near me with exposed guts seems to make the speakers buzz. The PC tower with the exposed guts that sits on the lower shelf and is blocked by another PC tower with exposed guts that is out of use does not cause my speakers to buzz. Any idea what is happening? I sure would appreciate an analysis. Thank you in advance.
