Hi all. Got a Luxman here that is stuck in protection. Problem is the service manual is so bad that there's no voltages on the schematic.
Here's what I know about it so far:
No shorts showing on the DBT.
Front lights come on but unit doesn't come out of protection.
All fuses are intact.
Voltages on output transistors are stable and identical on both sides.
Voltages on other power amp transistors are the same on both sides.
Audio tracer reveals good strong undistorted sound right around to the relay.
Relay has 8mv on one side and 10mv on the other.
New relay subbed in (no difference).
Three power supplies showing:
1) +/- 70.0v
2) +/- 60.5v (this is running pretty close to the edge with 63v main caps)
3) +32.97/-33.90
Any help on where to proceed would be appreciated. Is that third supply where I should be looking?
Thanks.
1) +/- 70.0v
3) +32.97/-33.90
Thanks.
