superdog
AK Member
I had been keeping an eye out for an int amp to build a 70s vinyl system.I was going to build it around a 70s receiver but would rather do it around a good 70s int amp.This was found at a thrift store and there is no output.It comes out of protection but no output.I can faintly hear the output when the volume is turned way up.First any ideas on what may be the issue perhaps known to these units?Second in some research I have seen that these are a bit different from most run of the mill amps in they seem to be built to higher standards and therefore requiring more for a rebuild(special caps from Japan?).Also the phono sections are claimed to be quite good(my reason for wanting to) but they are also more complex in the adjustments and also I don't know what the linear adjustments are for and haven't a clue on the bottom two adjustments.I just want a very good phono amp and this having two phono outputs is appealing.I am not any tt expert.Is this more than I need?My TTs are a Sony PS8750 and Technics SL1200.Is the rebuild more than the average tech can handle?I'm willing to throw down for the repair and recap as this is the end line for my tt trip if it is the right one.Its the 70s sound and appeal I want.
