Luxman M-02 Power Amp BBQ
Discussion in 'Solid State' started by madtech, Oct 28, 2018.
  1. madtech
    madtech AK Subscriber Subscriber
    700
    New Brunswick
    This one has been under my bench for years and I've finally found the time to have a look. Seems like the previous owner blew the 1302/3281outputs on the right side and attempted to replace them with some "high quality" replacements. Previous stage was also BBQ'd. When they installed the replacements they didn't bother cleaning up all the carbon. Luckily it wouldn't come out of protection with all the NTE junk in there and nothing else fried. Bought some OnSemi replacements for the outputs. Capacitor C110 is listed as 1000pf but has no listed voltage in the shop manual. It's hooked up between the base and collector so I'm thinking 100V should do it?
    Copper side is a bit of a mess but repairable. Heat sink for the outputs looks like something from Star Wars.
    Looking forward to getting this running again after the abuse it's been put through. I've re-capped the C-02 pre-amp and it's ready to go.
    swamppirate likes this.
  2. slimecity
    slimecity Super Member
    3,156
    New Zealand
    Your pics arent showing up.....
  3. Blue Shadow
    21,976
    SE PA
    Well if the C-02 is ready to go the M-02 should be next. Good Luck. I'll check back to have a look at the pics when they show up.
  4. madtech
    700
    New Brunswick
    If you look close, you can see where they soldered two resistors in series to come up with the desired value....... :)
  5. Blue Shadow
    21,976
    SE PA
    When I was repairing crisp circuit boards in the MB3045 amp, I was told that the char can be somewhat conductive. I removed it completely and rebuilt the board with epoxy and some board shavings for color. Works a treat and the amps sound wonderful. I don't think Luxman had heat transfer engineers, just co-op students doing that part of their design. But boy their units sound nice.
    Heat pipes became common in the early 80s. must be horizontal so the liquid flows to the heat source, evaporates and flows to the sink area to condense. A lot less metal needed for these than the regular finned sinks we see all the time. They must work just fine, lots of companies used them.
  6. lico
    lico AK Subscriber Subscriber
    2,169
    Now this is a thread I like to read instead of the usual "what caps should I get" for a recap. Make it sing!
    luxmaster likes this.
  7. wmgwizard
    wmgwizard Super Member
    3,270
    Browns Mills NJ
    I miss my C-02/M-02 combo every day, one of those things I should have never let go.
    Good luck with your repairs, hope it all works out for you.
  8. ryuuoh
    ryuuoh FFXIV Summoner Subscriber
    9,345
    Marina CA, USA
  9. madtech
    700
    New Brunswick
    Yes, I suppose that's something else that I should look at. I don't need anymore components turned to charcoal.....
  10. madtech
    700
    New Brunswick
    Re-cap is complete. Have to re-flow the entire main board. Almost every 1 in 3 solder joints needs to be redone.
    Nightwisher and ryuuoh like this.
  11. madtech
    700
    New Brunswick
    Solder re-flow is all done. Schematic shows in red what was blown. I'm debating pulling all the remaining transistors or taking my chances with my dim bulb tester......Nothing to the left of the red line has been tested.
    Nightwisher likes this.
  12. Nightwisher
    Nightwisher Farer In The Goldilocks Zone Subscriber
    3,330
    South Carolina
    Good to see you getting this up and running! My C-02/M-02 combo is my daily driver.
    madtech likes this.
  13. madtech
    700
    New Brunswick
    Just noticed the output emitter resistors (.22 ohm\ 5W) are from 4 different manufacturers. At least they were the same color. Yet another Mouser order......
  14. madtech
    700
    New Brunswick
    The new outputs are installed. Dim bulb test went fine so it looks like there are no shorts. Flipped to main power and it won't come out of protection......bummer. The red LED D102b on the right channel won't light up, so it looks like I have an issue earlier in the stage. At least there is no smoke!
    ryuuoh likes this.
  15. FootFungus
    FootFungus Super Member
    1,118
    Dallas
    I've got a M-02 that's toasted in the exact same place - completely roasted through the board though.
    There are a lot of fusible resistors that can fail, so check those if you haven't already. Nice work so far.
