Hello, I recently got a T-102 tuner and are having some questions for its antenna. The first picture shows the back, on the left marked FM 75ohm and then in the middle a row of four marked as FM 300ohm, 75ohm, Ground, Loop, and AM. Can someone please educate me what these mean and how to use them. On the second picture I show what I believe to be the antenna that came with the unit and on the third picture the wires with two ends which I guess should be connected to the back in some way. Do I miss some parts? If not how to use them? Thank you.
