macaltec
Metal Master
OK, I have had this receiver for quite a while now. I have the service manual and schematics. It worked fine for several years and then it dropped a channel. It got new fuses and new output transistors. I am not very confident in the quality of the outputs I bought and it has been several years since I bought them. I have not used the unit in a year or so because it kept blowing fuses, not right away but after a bit of use each time. More like casual attempts at use never any extended periods of time. I am remembering that I was never able to really turn the volume up much before it would start to sound bad and/or blow a fuse since the initial "repair" of the outputs. I have several projects but this is the one that needs to be right. Should I look at a complete re-cap? Or just recap the amp section/pre-amp section?
All that said, I need some help.
Thanks
Thanks
