miniman82
Go Navy!
I picked up this ratty MC2100 from a guy in cali a couple months ago, and wasn't really sure what direction I wanted to go with it so it sat for a while till I could make up my mind. Since the electronics had been gutted all I had was a chassis, the transformers, terminals, and a whole lot of rust.
In the end I decided this would be a good home for the pair of ECG-1328's a friend gave me, so I set about rehabbing everything.
I had the chassis sandblasted to get off as much rust and old plating as possible, and it came pretty close to original bare metal with some slight pitting where the exposed metal had corroded. I then had the same place do powder coating in satin black all over everything, which is why I call this amp 'BLACKOUT'. The potted transformers couldn't be coated because the baking might have melted the tar in them, so instead I stripped them by hand and shot them with flat black spray paint.
I used a cut in half heat sink from an old JVC receiver for the output modules, and fabbed the rest from stuff I had laying around. The PSU filters are donors from an MC2120.
It sounds pretty good, aside from a slight lack of high end. This is the first amp I've owned where I actually had to use my C32's EQ to brighten the top end a little on program material. Other than that, I'm happy with how it turned out.
Voltage into an 8-ohm dummy load is 28v, which ohms law pegs right at 100 watts so pretty close to what the original should be.
Thoughts? I say it's better than going to the dump, that's for sure. Not completely Mac anymore, but the important stuff is there.
