knockbill
Lunatic Member
I'm revisiting this 185, since I had to replace a wonky fuse holder yesterday,,, Replaced the old 7025 phono stage with a 12AU7/12BH7 and Volume controls last winter, similar to Gordons mods, in this thread.... http://audiokarma.org/forums/index.php?threads/12au7-vs-12bh7-circuit-mods.747842/
but had some low level hum that I decided to chase while it was on the bench... Spent the most part of yesterday, til 2AM! and came to the conclusion it wasn't PS related, but ground loops in the input circuits/jacks... Here's what I found...
The hum can be eliminated by connecting the preamp jacks to line input (tape deck), or shorting jacks... but that eliminates the 1st (12AU7/VC) stage ... I suspect the problem is with the chassis grounds and the original jacks,,, there are two shorting jacks on the preamp stage, one the 1st(old 7025 phono, now 12AU7 stage), the other jack is open...
The goal is to use the old 7025 ceramic phono input w/VC , rewired for 12AU7 and retain the line input without the VC for use with the original passive tone stack, if I want to re-use the console... Other than the GL hum, the amp sounds very nice...
Not sure I can have it both ways,,, but I want to get rid of the ground loops and hum, regardless...
Figured its time to call in the cavalry!!
Thanks in advance...
