Tube Radio
Super Member
I just purchased a Magnavox AMP 142 which was stripped of most components except tube sockets and the power transformer. The 12AX7 socket is gone as well.
I found the stock output transformer.
I plan on rebuilding it but I may make a change or two.
1. Moving the rectifiers to where the speaker output jack was as there's an identical hole next to it and I think they are octal socket sized. May use a 5U4 versus dual 5Y3 which will reduce the 5 volt current by an amp.
2. Replace the phase splitter with the type of phase splitter using one triode to produce both the normal and inverted signals (forget what its called) which will most likely be a 6SN7.
I then have an extra octal socket.
What I'm wanting to do is at minimim add a low pass filter to drive a 15" Jensen speaker to add some bass to an antique radio and also I possibly will add a second HI-FI input given the Jensen and it's three tweeters sound quite good.
How would I do the filter and second HI-FI input? The filter needs to be a low pass of 150Hz and at least two pole.
