Maintaining a Sansui AU-517
Discussion in 'Exclusively Sansui' started by Tdogzthmn, Mar 10, 2017.
  1. Tdogzthmn
    Tdogzthmn Active Member
    215
    Hello,
    I recently purchased a Sansui 517 in great condition from a seller off Craigslist. Prior to picking up the amp, I had been reading that it can be a good idea to replace/upgrade some of the capacitors and resistors to bring the amp back up to spec.
    Before deciding to make any alterations or repairs, I though about bring the unit to a local repair shop that advertises its work on vintage audio gear to check if the amp is functioning optimally. If the amp is functioning properly is there still a need to recap it?
  2. inductor
    inductor Super Member
    1,517
    uk
    been answered in another section
  3. Hyperion
    43,041
    Hertfordshire, UK
    They can test it and tell you it's functioning optimally, but if it sounds lifeless (which is likely at this age) then it needs to be reconditioned - and I don't mean 'recapped' I mean reconditioned, in my book there is a difference. However, if they test it and say it's OK - and you like the sound of it, then that's OK too.
    NB: Tdogzthmn - It's considered bad form to post the same question twice.
    skippy124 likes this.
  4. Tdogzthmn
    215
    Once I'm able to discuss the amp with the repair technician I will follow up in this thread.
    I've been trying to learn more about the usual issues with these amps so I can properly vet the repair shop's knowledge of Sansui gear.
  5. roger2
    roger2 . Subscriber
    3,104
    indiana
  6. Tdogzthmn
    215
    Does anyone have tips for removing that reddish brown glue that was used under the capacitors? Is a solvent required or can it be chipped away without damaging the board or surrounding components?
  7. Hipocrates
    Hipocrates Anti-Muppet
    1,413
    Costa Rica
    A drop of acetone and a wooden little stick, is what I use. After that, alcohol and a q-tip.
  8. Hyperion
    43,041
    Hertfordshire, UK
    I am pleased to see you ask about this, :) essential in my opinion, but so often forgotten.
    Multimode, Overundr1 and skippy124 like this.
  9. Overundr1
    2,417
    Mississippi
    Quote --- A drop of acetone and a wooden little stick, is what I use. After that, alcohol and a q-tip.
    Forgot to add the gallon of patience :)
    Godi and Hyperion like this.
  10. Hyperion
    43,041
    Hertfordshire, UK
    And some of the alcohol should be taken orally for stress free results. :D
    (a somewhat different kind of alcohol - to be clear ;) )
    Edit update
    And in other news, I have just refitted the power modules to the AU-517 I am reconditioning, DC offset and bias set perfectly. I have to do 'the business' to the Phono amp and remount the new speaker terminals, then it is done.
    pete_mac, Hipocrates, MBuras and 2 others like this.
  11. Tdogzthmn
    215
    I do have some nice japanese whiskey that ought to do the trick!
    Overundr1 and Hyperion like this.
  12. Tdogzthmn
    215
    I'm now in possession of the amp and overall its in great condition. There are some minor scratches on the top and sides which I can sand and repair easily. The faceplate is very nice but there are one or two tiny scuffs that I'd like to address. The aluminum black seems to be a good method to address these but i'd like to hear for others who have restored amps.
  13. LBPete
    11,238
    Long Beach, CA
    Please post the serial number for the database.
    - Pete
  14. Tdogzthmn
    215
    My serial is 227060167
  15. Tdogzthmn
    215
    I've had a few days with the my newly refurbished amp and I am very pleased with its performance. I've owned a few SET amps and the Sansui is somehow able to present music in a similar way. Its hard to articulate but its a warm familiar sound that brings back memories of my 2a3 integrated amp. The bass is rock solid and very articulate coming through my Vandersteen Model 1C speakers. There is more than enough power for my speakers and I've actually added some attenuators to help add some play to the volume. Looking forward to letting it burn in more and settle down!
  16. LBPete
    11,238
    Long Beach, CA
    Thanks.
    - Pete
  17. Tdogzthmn
    215
    Can you tell my future based on the number?
  18. LBPete
    11,238
    Long Beach, CA
    Yes, I see many years of audio bliss. That and your AU-517 was built on assembly line 22 during June of 1977 and was the 167th unit built on that line that month.
    - Pete
