Man vs. Beast: CA-2010 restoration project
Discussion in 'Yamaha' started by Dadbeh, Jun 22, 2018.
  1. Dadbeh
    Dadbeh Schrodinger's meerkat Subscriber
    555
    I intend to document every stage and every issue that arises. I will be recapping and dealing with meter lights at first and go from there. I would also like to do some resurfacing on the wood to make it as shiny as I can.
    r_deming likes this.
  2. avionic
    avionic " Black Knights " Eagle Keeper Subscriber
    46,296
    Fort Dodge, Iowa
    Is everything else working properly besides the lamps ?
    Moby Dick and Dadbeh like this.
  3. avionic
    46,296
    Fort Dodge, Iowa
    Fix issues first before you start swapping out parts.
    Dadbeh likes this.
  4. Mr. Yamaha
    Mr. Yamaha Not so much Yamaha lately...
    899
    Amsterdam Area, The Netherlands
    CA-1010 or CR-1020?
  5. avionic
    46,296
    Fort Dodge, Iowa
    CA-2010
  6. Mr. Yamaha
    899
    Where did you read that? It isn't in this thread :dunno:
  7. avionic
    46,296
    Fort Dodge, Iowa
    Mr. Yamaha and Dadbeh like this.
  8. petehall347
    28,327
    uk.. the middle bit
    2 threads on same thing is confusing to some of us .
    Mr. Yamaha and avionic like this.
  9. avionic
    46,296
    Fort Dodge, Iowa
    That it does.....
  10. Dadbeh
    555
    sorry about the typo, it's on account of me being a doofus. it is CA-2010 could a moderator please fix it?
  11. Dadbeh
    555
    will do, i realize that im jumping a little ahead. just cant wait to have it singing.
  12. avionic
    46,296
    Fort Dodge, Iowa
    Its worth the wait..;)
    Dadbeh likes this.
  13. Dadbeh
    555
    its been picked up and its coming to daddy :D from oregon to eastern PA should be a couple of days :D
    i already bought all the caps to recap except the two big ones. i think it is 22k each or something like that.
  14. BobHol
    BobHol Old fart Subscriber
    739
    Fort wayne IN
    To me this seems like quite a challenge. The beasts I have let me know when they need feeding. Best of luck to you
    Dadbeh likes this.
  15. Dadbeh
    555
    so it works but upon more listening not perfectly. likely due to the short in the right channel speaker terminals that lasted few seconds or maybe it was a previous condition but now i see that after several minutes of playing, it makes crackling sounds and one or both channels go out and come back.
  16. avionic
    46,296
    Fort Dodge, Iowa
    Have a real close look at the power supply. Post a clear photo of the two large heatsinked transistors on the power supply board. Its located in the belly of the beast.
    Dadbeh likes this.
  17. superdog
    superdog AK Member
    9,780
    Southern Colo.
    Good luck.I had a 1010 that I really liked but issues so I let it go.2010 should be even better.
    Dadbeh likes this.
  18. Dadbeh
    555
    finally opened it up, while dirty, seems to be untouched. it actually seems to be slightly easier than A-1 to take apart. in the sense that there is a little more space in there to stick your hand in. imma start with the power supply.
    the problems are there also when using the pre pout to another amp so like avionic said, the power supply is the first thing to inspect.
  19. Dadbeh
    555
    this is just so clean. i dont see anything even slightly off. just that the board is darkened (scorched) under those two trans D476A and B566A. what is to be done about it?
    https://imgur.com/a/1ZwgvQj
    the back of the board, thge traces are better than my new amp.
  20. avionic
    46,296
    Fort Dodge, Iowa
    Mount the transistor and heatsink a little farther off the board. Or figure out how to get better ventalation in there.Larger heatsink ?
