Whitebear15
This is a strange fault, I switched my 1060 on this morning and there was a flash and a bang, the plug 3amp fuse, had blown.
Now heres the strange thing, I know that the amp will work ok when I change the mains fuse, its done this before but always worked after.
The bang and spark comes from the right hand side near the remote speaker switch, it might not happen for months and suddely it does it again, Im baffled have any AK members come across this before? Regards Rob.
Update: Well been reading lots of postings on 1060s blowing fuses, and begining to suspect the bridge rectifier could be the fault, I did a full recap last year and its only happened since that.
Im going to check the filter cap to see if I replaced it with a bigger capacitance, cant remember now, but that could be the suspect. Checked my filter capp replacment and its 10,000uf 80volt, so could this cause my problem? Regards Rob
