bktheking
Gitter Done!
This time it isn't mine, it's Ed Dantes. There's a story behind it, he'll share if he wants to. Basically, things after purchase aren't always what they seem. It was said in the ad that there was an issue with one channel and that it was cosmetically perfect. The pic in the ad showed a working scope, as it should with full stereo seperation.
After hooking it up, 1 channel was dead and 1 channel severe distortion, the scope display showed a line in audio mode tuned to FM and the display dial was missing some of the numbers- clearly the seller was a liar.
Anyways moving right along- the dead channel consisted of 2 smoked resistors and 2 dead outputs. I have marantz 2235 outputs in the one channel for now and it sounds fine, the true 1000 and 1001 motorola outputs are on there way from NY. The issue with the other channel was a blown transistor- Q1002 which was replaced with NTE159. After it was replaced I set all the audio adjustments and it acted normal again.
On to the scope- if you have a receiver that will move horizontal and vertical and displays something properly, the scope driver board is not the issue. On these units the MPX Matrix board is reponsible for sending a right and left audio signal to the FM selector switch which in turn goes through your display selector switches to the scope driver board then to the tube. If one of these is missing you will have issue. The issue with this thing- someone had already attempted to repair it, here's where the puzzle begins-
