willyrover
Super Member
I have been working through a 2215 "barn find" and other than new trimmers that are on the way, I have one issue left to address and I'm stumped.
FM Stereo isn't working. I don't have FM alignment equipment but I was able to confirm that the 19kHz pilot signal is arriving at the MPX board and the doubler to 38kHz is working.
I have pulled transistors and capacitors and they test ok. I've check diodes and resistor values.
The muting IC on another board is also working and I am able to adjust the muting threshold. The same voltage that switches the muting IC is supposed to switch H403 and arrives at the MPX board at pin J404. When the wire is connected to J404 I am only getting 0.6volts. When I lift the wire off the pin, I get 8volts.
I tried feeding pin J404 with an external DC power supply and couldn't get more than a volt or so out of it - as though something is shorted.
Another oddity is that I am reading 39VDC across C415 and C416. These are rated 16V on the schematic and 25V in the amp. They test fine.
Does this issue sound familiar to anyone?
