there is a marantz 2215 for sale locally for $75 the owner claims to be in perfect working order is this a good deal? it would be my first piece of marantz gear
The 2215 and 2215B are two totally different receivers. I am working on both right now.
The 2215 is much deeper than the 2215B.
If you check E-bay, it would appear that the 2215 is more rare.
I would say that is a good price for 2215. Not so good if it were a 2215B
Rob
The "B" series is just a later series of amps. It is not "improved", just different, newer. Why there are some models that are named 2230 or 2230B, for example, only means that both are rated at 30 watts per channel. That is all they have in common.Could you be a little more specific? I always thought the "B Series" represented an improvement over the corresponding "letterless" version. What is it about the 2215 that makes it better in your view?
John
And, since the B series is newer, it means that the build quality is worse, as this is standard practice for any type of gear. The later it is, the cheaper it was to produce. That is the only reason the B series exists. To cut costs and increase profits.
Hello all,
Complete noob here. I bought a 2215B at a yardsale last weekend for $5 bucks............... Has anybody ever hooked one of these up to a PC?
It is like comparing the Luxman R-1500 with the R-1070. Both are rated at the same wattage, but they are totally different amps. Marantz were just being odd here, using the same model number scheme twice.
Has audio gear improved over the years? Nope. Just cheaper to make.
