Hiyas guys~ Working on a 2216, serial# U062530
I decided to create a thread on this repair, it's my opinion that good threads can be useful for many years down the road. I've already got several posts in diff threads about this repair and anyone trying to follow - would find it difficult.
Obviously, anyone with advice on this repair should speak up.
Starting out, I only identified the hum and the distorted sound when the volume was turned up. Might be more problems, but both channel outputs seem to be working.
Worked on tracing the hum first. Hums on all inputs, level (loudness) does not change with volume control, Hums with nothing on the inputs.
Using a scope, I could identify the hum as between 100-200 Hz and mostly around 120 Hz. No hum present on the incoming side of tone board PE01 but hum is present on outgoing side of PE01.
So, I rebuilt PE01 with new transistors and new caps - left OEM resistors.
No change on hum.
Additional testing found the hum is being introduced to PE01 by the power supply board P800. Quick voltage tests show that the only transistor 2SC1407 on this board may be bad - ordered a new http://www.mouser.com/ProductDetail...GAEpiMZZMshyDBzk1/Wi2apbjiIOs04CXdH%2bWi22xM=
This board also shows some corrosion on a couple resistors\diodes. If I can get good pics, I'll attach. I can't tell if this corroded "on it's own" or if someone spilled a small amount of something on the board. I did read that possibly the glue on that board (and there is glue in that area of corrosion) was faulty in that it was both corrosive and conductive?
Will replace that 2SC1407 and all caps (and clean corrosion) and I'll report back.
No change on hum.
