Title here describes my situation, so going to pick up this thread and hope someone can help solve this vexing problem on my 2225. I do fairly well with most aspects of vintage receiver repair - EXCEPT FM.
I've read as many threads as I can on this topic, but can't seem to get a stereo FM light. Here's what I know:
1. No Stereo light on FM. Works fine on Aux, Phono, Tape. BTW, the original was burned out, so I replaced it with an LED with a resistor in line.
2. Flushed tuning capacitor shaft contacts and function selector switch with non-residue contact cleaner twice. Flushed mono switch also.
3. Though the unit seems to play clearly in mono, the signal strength meter never gets more than halfway from rest position to the first mark. Yes, there's a good antenna.
4, The signal strength meter runs up past 4.5 on a good AM signal, so I know it works.
5. The center tuning works, but hangs a bit to the left on no signal. Doesn't seem to swing equally in both directions (I've seen this on these classic Marantz receivers before).
6. FM muting on shuts down all sound across the dial.
7. Checked all voltages on HA-1156. All are very close to the diagram specs in service manual.
8. I've flushed and then tweaked R304. Nothing. Adjusting it doesn't seem to affect any voltages on HA-1156.
9. Have checked voltages on all transistors on the 300 board, and all seem to be pretty close to voltages in the service manual diagram. Nothing really odd to report.
Some comments lead me to believe the FM discriminator is the problem. I don't know what that is or what components to diagnose. But it seems logical (signal strength, FM muting) that the problem has to do with not getting a good signal through to the FM stereo circuit. The only equipment I have is a DMM.
Not sure where to go from here. Suggestions?
