Here's a simplified explanation of the MPX operation for the 2230, 2245 and 2270.
There is a good description in the service manuals for the 2245 and 2270, but it's kind of hard to follow.
The 2230 is slightly different.
Wire-anded: the junction of two or more components where either one can pull that point to or near ground potential.
IF signal strength is monitored by H306. If IF signal strength is above muting level, H306 is ON, H307 is OFF.
If there is excessive noise, then H552 is ON which is wire-anded to J305, keeping H306 OFF.
If the discriminator is outputting DC due to the tuning being off station, either H560 or H561 is ON which are wire anded to H307 as well.
If the station is properly tuned, not noisy and the signal strength is high enough,
H306 is ON, SS OK
H307 is OFF, SS OK AND
H552 is OFF, Noise is OK AND
H560 is OFF Tuning centered AND
H561 is OFF Tuning centered
If SS, Noise and center tuning OK then:
H308 is ON allowing audio signal to pass to the center tap of the 38kHz transformer.
H302, 19kHz amplifier is enabled by H303.
If the 19kHz pilot is present from the broadcast station, then it is doubled to 38kHz by H304 and if of sufficient amplitude to decode stereo, H305 turns on causing the stereo lamp to illuminate.
The left and right matrixed audio signals are recovered by H317-H320, de-emphasis is applied, then they are amplified, filtered of high frequency noise and sent along through the selector switch to the preamp.
Tom
