Marantz 2230 phono buzz when turntable connected to power
Discussion in 'Marantz Audio' started by sploofer, Nov 14, 2017.
  1. sploofer
    sploofer Member
    98
    Chicago, IL
    I have an unusual problem that I can't find a solution for.
    My Marantz 2230 will produce a buzz while in phono mode. It will only produce the buzz when RCAs are plugged into the phono. If RCAs are not plugged into the phono, the buzz will go away.
    I found that if I connect my turntable to the 2230, then unplug the turntable's power, the buzz significantly drops. Is this a grounding issue? The part the puzzles me is that the buzz will also show up randomly and then disappear the next day.
  2. wurlyman
    wurlyman Active Member
    301
    Sacramento, CA
    Your 2230 probably has a grounding screw on the back of the receiver near the Phono inputs. You need to ground the turntable to the receiver. My Technics 1200 turntable has a black ground wire with a lug spade running along with the RCA plugs for this purpose.
  3. sploofer
    sploofer Member
    98
    Chicago, IL
    The turntable has been grounded, it's something else.
  4. quaddriver
    quaddriver 120 What's per channel Subscriber
    Im doing a 2230 at this time...read my thread as I had mystery buzz's. I still get one from the TT when its plugged in and OFF due to what it does to the cartridge.
  5. bktheking
    bktheking Gitter Done! Subscriber
    13,049
    Ottawa Ontario
    Do yourself a favour and service your phono board. It has 2sc458's on it - junk. I've also seen that main cap coupling ground to power go bad 100uf 50v - also some vd1212's that should be replaced with double diodes. Service is properly and the hum should go away. Put new transistors on the board, caps and diodes.
    CohibaJoe likes this.
  6. Northwinds
    Northwinds Huh? Turn what down? Subscriber
    7,089
    Connecticut
    It might be worth a look at the inside ground solder joint of the TT, not just the ground lug. My 1200mk2 had a hum to it even though it was grounded to the preamp. Drove me nuts until I took the tonearm off the 1200 and saw a bad solder joint. Reflowed it and no more hum
  7. bktheking
    13,049
    Ottawa Ontario
    Yes could be the TT as well. Still I don't trust those old components on that board if it hasn't been redone.
  8. sploofer
    sploofer Member
    98
    Chicago, IL
    I've actually recently had this serviced, so I'm not sure what the issue is.
    This sounds weird, but this mystery buzz only appears during the evening, right around 5pm. I've never heard it during the day.
  9. sploofer
    sploofer Member
    98
    Chicago, IL
    To add to this, I want to clarify it's not the turntable. I've switch out my Marantz for my Pioneer receiver and no buzz what so ever.
  10. misterguitar
    misterguitar Active Member
    270
    Ive seen this happen sometimes if the headshell wires aren't connected right. Double check em.
    hm sorry just noticed you said it work on the pioneer. That's probably not it then. Sounds like a bad transistor. The buzz only happens when you are on the phono setting? Have you tried switching to other inputs? If so does the buzzing follow?
  11. sploofer
    sploofer Member
    98
    Chicago, IL
    Buzz is only in the phono stage
  12. misterguitar
    270
    BK is right. Get rid of those 2sc458's on the phono board. They are known to fail buzzy. On one other occasion I had a friends have a 2sc1000 on the phono board go flaky. (Fix a lot of Marantz stuff for friends around here. I'm practically a charity lol)
  13. Karl Ty
    Karl Ty New Member
    42
    Hey Sploofer,
    Were you able to fix your buzz problem? I have an audible starting at 12oclock position onwards. Also gone when you take out the rcas in the back.
  14. wurlyman
    301
    Sacramento, CA
    I had that happen once. It was a bad ground on the cable, nothing wrong with the amp at all.
  15. nbarber
    nbarber I was once told "That is a damn good stereo".
    1,067
    Seattle
    Try rotating the power on the TT plug 180 degrees, with non-polarized plugs it is easy to not have neutral and hot synchronized. I had a buddy with 2285B with the same issue and that solved it.
