audiomaniac2
Hi folks, hoping one of you experts out there can help me.I have a problem in the pre and tone amp board Pe01.
I have changed out all the electrolytic caps on the board and all the transistors. The problem is is that the left channel will drop out now and then.Mostly if i start on low volume. When it drops out i have a signal on the volume control output so i know its not the volume control. If I touch my scope probe to various points in the circuit the channel drops in . sometimes dropping out when i lift off the probe or stays on. I can put my finger on the on the board also and does the same thing. Also if I turn the volume control up high enough it will kick on.The power amp is fine.
