zaskarx
About a year ago I re-capped my 2240, it sounds great but about a week after I finished the recap the FM section output dropped to the point where it is only audible if the volume is turned up past 1 o'clock or so and even then only barely.
I've been living without FM since but would really like to fix it I've downloaded the service manuals and studied the schematics, I've verified that all boards related to FM have the proper DC voltage. I've also double checked the values, orientation, and solder work on all of the replaced caps.
I suspect a failing diode or transistor but instead of testing each one I thought I'd check in to see if anyone can help narrow down where the problem may be.
