Kevbo
Member
I just posted a thread about a Stereo Light issues, but wanted to create a separate thread since this is slightly different. I replaced the factory lights in my Marantz 2240B receiver this past weekend with LEDs, every single light, including the tuning needle. Well, trying to get the front panel out just to solder, I ended up having to remove the tuning string in the front and tuck it away. I never removed it from the tuning wheel on the right (wrapped around three times). After hours of working to get the string back on, I may have lost some tension. The needle slows down to a stop in the middle, but with enough turns, it will eventually travel to the other side. I noticed the track it moves on was slightly bowed (concave, so it gets tight in the middle of the tuning meter). Anyway, I am now off quite a few frequencies numbers when tuned in to a station.
My needle housing is glued (or rosin, maybe) to the string, and that is the only thing I can think of to try and remove to slide the need to the proper spot on the meter to have a more accurate reading for tuning. Any suggestions on how, or if I should even attempt to try and "re-tune" my needle? Thanks!
