Juanbanzai
Hoping someone can help. I'm recapping a 2245 and got as far as the protection circuit before developing this problem. I posted something similar about this issue a few weeks back, but now I'm really stuck. After recapping the P800 board and replacing the relay, the first test saw the relay closing immediately. I got audio from the receiver, but that relay closing right away is not what is supposed to happen according to the service manual. While trying to track down the issue, on another test, it got to a point where the relay failed to close at all. That's where I'm at now.
I tested H809 and H8010 and found they were both bad. H808 had tested fine. I replaced 809 and 810 today with a pair of C2383s and that didn't fix anything. In fact, I tested the two new 809 and 810 transistors and they've both blown out. I've followed the circuit and found that both H807 and H804 (diodes) are testing bad in-circuit... but out of circuit they tested fine. I'm going to start voltage tests per the schematic to see if anything is blatantly wrong... but I'm hoping someone can clue me in on what to look for before I blow out any more transistors.
Thanks very much for the help.
Aaron
Aaron
