Marantz 2245 voltage adjustment problem
Discussion in 'Marantz Audio' started by AngelAT, Jul 13, 2018.
  1. AngelAT
    AngelAT Active Member
    124
    Hello everybody!
    I have a Marantz 2245 - i believe that it might be from the first productions (1001-3600). What makes me think like this is the fact that my unit does not have a main fuse at the back. (BTW i can not check the number because the Marantz plate at the back is missing...)
    The story:
    I partially restored the phono board p700 - i changed c713 with nichicon 100 mF/50V, h707/708 and h709 with 1n4148 x4. And I changed the notorious h705/706 with 2sc2240. After finishing I powered the unit and i think there was no problem.
    I cleaned the contacts of the relay and recapped the power supply board - mainly with nichicon. I only put some other brand at c802/804. When I powered it up the relay ticked and after that there was some smoke coming (I think) from around c803/804. That is why i returned the original c803/804. There was no smoke and the relay is ticking.
    The problem:
    When I started to adjust the voltage (I connect to j802 and j803) and the DVM shows 44 volts. When I turn r809 there is no change at all.
    What have I done wrong?
    How can I fix this problem?
    Any ideas are welcome!
    If you need further info, pls ask.
    Thanks in advance!
  2. wlhd1610
    wlhd1610 Penny and her new friend Sponsor Subscriber
    2,787
    Catskill NY
    Are you saying you changed each one of the H707/708 and 709 with four 4148's in series or between the three you used a total of four 4148s ?
    Bob
  3. petehall347
    28,334
    uk.. the middle bit
    The problem:
    look at the schematic first maybe ?
    tell us where each meter probe was . i can only guess its between those 2 places .
    if trying to set 35v go from chassis ground to j802 .. am sure this will be in error thread .
  4. AngelAT
    124
    Hi Bob,
    Thanks for the quick response!
    I used total 4. Two in series for h709.
    Angel
  5. AngelAT
    124
    Hi Pete,
    These two places were specified in the service manual. So one of the probes was at j802 and the other at j803. Looking at both schematics (for old and newer versions) I do not see any differences around j802 and j803 in p800.
    Any ideas?
    Angel
  6. AngelAT
    124
    I checked the different pin voltages and this is what came out:
    -j804 and j805 = nothing
    -j803 and j806 = 33 v
    -j801 and j803 = 13,1 v
    -third terminal strip b/n phono and tone board = 34 v
    Angel
  7. petehall347
    28,334
    uk.. the middle bit
    there are errors in the manuals . but this time its not wrong .
    j804 j805 are AC voltages .
    h805 might be shorted emitter to collector . best check it .
  8. AngelAT
    124
    Thanks Pete,
    Actually it came to be h806.
    I read that I can replace it with 2SC2240.
    Is this OK?
  9. AngelAT
    124
    One more thing:
    From the data sheet of the c734 (y) I saw that pins are B, C, E.
    But it was put vise versa from what is printed on the board (? IMG_20180714_001155[1].jpg View attachment 1235210 IMG_20180715_111642[1].jpg )
    Is it possible that there is a mistake and more important:
    How to place the replacement?
    Thanks!
    Angel
  10. petehall347
    28,334
    uk.. the middle bit
    was it original ?
  11. AngelAT
    124
    the c734?
    I have no idea, but should be.
  12. AngelAT
    124
    I placed the c2240 the way c734 was placed.
    And smoke came from r804
    Any ideas?
    Thanks!
  13. petehall347
    28,334
    uk.. the middle bit
    2sc734 is ecb .. board layout agrees with schematic
    2sc2240 should be ecb as well .
  14. AngelAT
    124
    ok, maybe I found the wrong info.
    Is 2sc2240 a good replacement?
    thx!
  15. petehall347
    28,334
    uk.. the middle bit
    Will look later sat in hospital waiting to have my foot looked at it swelled up .
  16. EastPoint
    4,807
    Milwaukee, WI
    I believe the KSC2383 is a good sub for the 2SC734. Not sure about the 2SC2240.
  17. AngelAT
    124
    Get well soon Pete!
  18. AngelAT
    124
    Thanks!
    Will look at the specs.
  19. petehall347
    28,334
    uk.. the middle bit
    even with the 2240 in there that resistor should not have smoked . looks to be to limit current through h805 .
    what fault did h806 have ?
  20. AngelAT
    124
    h806 was shorted between E and B.
    Should I replace h805?
