callahan1973
New Member
Hey again, everyone! Huge help with my last thread so hopefully this one will solve my issue as well. I have read lots about faulty power switches in some Marantz models like the 2250 but supposedly this was fixed in the 2250b so I'm not sure where my power issue is coming from.
The power has always been a little finicky - sometimes you have to "hold your mouth right" when pushing it in to get it to turn on and stay on. It will often make the fuse lamps flicker and then shut down, never hearing the "click" from the transformer, with nothing more happening if you keep holding the button in. Sometimes it seems that if you directionally push the button in, usually down and to the left, it has a little more success but that's not reproducible consistently. If it starts to flicker and stays and I hear the transformer click, I'd say about 60% of the time if I keep it held in for 15 seconds or so and slowly let off the pressure it will stay on and the other 40% of the time it powers right back off. If I can get it to turn on and stay, it runs with no problems whatsoever, no sound issues, no power issues, it can stay on all day no sweat.
Does this sound like the power switch or something electrical in the transformer or somewhere else in the power circuit? Thanks everyone!
Edit: I should mention that a thorough DeOxit spraying of the power switch appeared to have a beneficial effect at first, with it turning on probably the first six times or so without incident, but after that the problem started to recur and now further DeOxit has not helped.
