I WILL TRY IT THI NIGHT!!!! HOPE IT SOLVE!!On the back is a switch it is labeled Attenuator . Move it to the Out position . That might do it . It controls sensitivity of FM signal
I have photos of the unit in my cell phone (who doesn't...) and it look like the attenuator is in IN position.It's outside just above the antenna inputs. It's a slide switch labelled "IN OUT." As Beamer said, if it's in the "IN" position, move to the "OUT" position. If it's already in the OUT position, get back to us, there might be something else going on.
Hello, unfortunatelly, the attenuator doesn´t improve the FM audio..... AM sounds with regular volumen....It's outside just above the antenna inputs. It's a slide switch labelled "IN OUT." As Beamer said, if it's in the "IN" position, move to the "OUT" position. If it's already in the OUT position, get back to us, there might be something else going on.
HELLO!!!Do you have an FM antenna connected?
Have you tried turning the FM Muting switch off?
hello!!!Do you have an FM antenna connected?
Hello!, when is push and un-push the mutting i hear no diference... could that indicates a problem?Do you have an FM antenna connected?
Hello!!!! Thank you!! in my country, (at least where i live and the on line stores ....) no deoxit available, so i have a spray called SILLIJET, dielectric, silicon based, according to the label, it does not leave any residue after evaporation. what do you think abou it to clean switches and potentiometers???You might need to clean the push button switches . Mono L&R, Tape Monitor(both), Mute Button . Leave the mute button in the out position when done . Also clean the selector switch . Use Deoxit and then work the switches in and out 20 to 30 times .A lot of the time with a Marantz dirty switches are the cause of odd problems .
Yes!!MUTING button out?
I would try that next. Hard to pick up signals without one....Well, i have no antenna...
Ok i am checking that!You need an FM antenna. They look like this:
https://www.amazon.com/Parts-Express-FM-Dipole-Antenna/dp/B000M9EREE
