Beamer302
I would like to know why when replacing on a 2275 amp board H713 (which was a bad 2sd382) with a MJE15030G (suggested replacement) and H714 ( a good 2sb537) with a MJE15031G(suggested replacement) the idle current won't trim down to 10mV ? 10mV is what the service manual says to set it at. I can only get it down to 48.5 mV. I had this 2275 up and running for a few weeks till H713 blew.Idle current was fine before then. Do I need to add more resistance somewhere ? Are these suggested replacement transistors wrong? The components on the board show no sign of heat stress. Should I start checking resistor values ? Thanks.
