I know it goes without saying you did check the main fuse and the fuse on the power supply. Do you get voltage to and from the power switch etc.
Removed the fuse and tested with a meter, not just eyeballed?
Is it dead as in no power and lights, or lights but no relay click or sound? It is possible the lights are all out. Stranger things have happened.
Be as specific as possible so the real experts can chime in. Pictures are always a good thing too.
What did you measure/test, where and how.
I've not heard of a 2325 blowing a transformer.
The 2325 transformers that were produced for Canada have an internal thermal fuse. Another AK'er recently repaired one and sent me some pictures. Here is his description: "A short bit of thin wire placed between the internal coil wire and one of the wires that exit the transformer case to the AC input". I've attached two pictures, one includes circles and arrows, many thanks to the AK'r who sent this.
Also discussed in this thread:
http://audiokarma.org/forums/index.php?threads/whats-this-inductor-fuse-inside-a-transformer.692377/
Not meaning to leap way ahead on troubleshooting the OP's 2325.
^^^ This is good info, good post! I believe the Canada models have a "C" after the model on the ID tag on the back or in the serial number but I'm not 100% on that. Member 'bktheking' might know that. Where art thou brother Brad?
Do an ohm check across the primary and secondary windings.
