t j
Apparently it can currently only be used as a power amp. I believe there's a 50/50 chance that I can clean it up and get the pre amp working, but may end up needing it professionally serviced.
Wood case is a 6 out of 10.
The faceplate has several deep scratches.
One tuner meter light is out.
It's being offered at $720.00, but I'm gonna try to get it down.
If it were you and this was all you knew, what would you offer for the unit?
Thanks in advance...
