Marantz 250 help
Discussion in 'Marantz Audio' started by Cumminscider, Nov 5, 2018.
  1. Cumminscider
    Cumminscider New Member
    24
    Was listening to music then one channel cut out and I saw this part arcing in the area circled. I shut it off and let it sit awhile, tried turning it back on the protection relay doesn't click anymore? Not sure what to check any ideas?
  2. bktheking
    bktheking Gitter Done! Subscriber
    12,991
    Ottawa Ontario
    Arcing-large amounts of dc , relay won’t click cause the amp is probably in protection.
  3. Cumminscider
    24
    Anything I can check with a voltmeter? I can't find any burnt parts, visually everything looks okay.
  4. ConradH
    ConradH Addicted Member
    8,041
    Canandaigua, NY
    The Marantz 250 is a nice sounding amp, but the design is fraught with problems. Fixing it (and applying the essential upgrades) is not for the inexperienced and you've almost certainly got way more trouble than can be fixed with a DVM. Suggest locating competent tech (maybe somebody here on AK) ASAP.
    Cumminscider likes this.
  5. wlhd1610
    wlhd1610 Penny and her new friend Sponsor Subscriber
    2,694
    Catskill NY
    ConradH is 100% correct.
    There are no less than 6 Marantz Technical Service Bulletins trying to address the issues that the 250 had.
    I'm doing one right now that had this happen....
    Bob
  6. ConradH
    8,041
    Canandaigua, NY
    As Norm Abrams always said on his TV show, "And always wear these, safety glasses!"
  7. spark1
    spark1 Super Member
    1,769
    The Great Midwest
    I assume you have no daughters.
  8. ChrisMarantz
    ChrisMarantz AK Subscriber Subscriber
    2,563
    San Francisco Bay Area
    Awesome Failure - Chris
  9. tranguru
    tranguru Active Member
    203
    Brussels
    Maybe just a bad elecro cap - but I doubt it....
    probably need to check for DC on the outputs...
  10. bktheking
    12,991
    Ottawa Ontario
    Black to chassis ground, red to pin 5 and then 7 on the relay board- DC. Tell us what you read. Pin 5 in one channel, 7 is the other.
  11. bktheking
    12,991
    Ottawa Ontario
    Bad electro cap with arching? I doubt it too.
  12. airtime
    airtime Super Member
    2,209
    Central Arizona
    The 250 may look simple to fix but it's not. They worked very well with few problems. HOWEVER!!! once they needed to be fixed that's when the problems in the design become VERY apparent. You WILL need a skilled tech to not only fix it but do the upgrades and testing to undo the unstable design flaws.
    This is not a simple put in some caps and a transistor fix.
  13. ChrisMarantz
    2,563
    The mantra for a Model 250 repair / rebuild / update has to be "Complete and Thorough with the greatest attention to detail" otherwise the end result will be a soft but unmistakable "poof" - Chris
    airtime, catrafter and wlhd1610 like this.
  14. Cumminscider
    24
    Thanks everyone I eneded up trading it for some speakers. If I do get it back by some chance I will revisit this post. Thanks again.
