mikey99
Trying to set the bias....idle current on my Marantz 2500 and it wont go above .4 mv
on the right channel. Measuring on PX01 TP3/TP4 on the right channel. The left channel will
set correctly at 25 mv.
The DC offset is set to 0 on each channel. The receiver works great, both channels sound
great and the volume levels are the same between channels. I did notice that when I turn
the volume up, the voltage increases and will go as high as 25 mv, at high volume levels.
This 2500 had a blown right channel and had all eight of the right channel outputs
replaced with On Semi MJ21193G/MJ21194G awhile back.
At that time I also replaced the two TO-220 devices D610/B630 on the heatsink with MJE15032G/MJE15033G.
Also replaced two bad/open transistors on the P700 board, Q711/712 with MJE340G/MJE350G.
I did not replace either QM02 or QM01 (the sandwich) on the right heatsink. I did remove
these parts, cleaned and applied new thermal grease, and tested with an ohmmeter, comparing
to parts on the left channel.
I'm wondering if this inability to set bias could be due to different electrical characteristics
of the new parts I've installed. I'm thinking that eventually I may need to remove the amp tunnel
to troubleshoot...but would like to avoid that if possible.
Could either QM01/QM02 be bad and causing this type of problem ?
