My neighbor just around the corner, and a good friend, told me he had a Marantz with a scope in it down in his workshop. Turns out it was a 2500! I finally have time to start refurbing it for him. Here it is:
I brought it up slowly via my DBT and using a variac to bring up the AC slowly. All seemed well and I got the "click" of the relay. After going diect (no DBT), it came up okay and draws about 0.75Amp AC, about right for a beast at idle. A quick check of the speaker terminals revealed DC noffsets of 5 and 10 mV so I connected speakers and after some fiddling with controls got some sound. It's in dire need of DeOxit for sure!
Next I played with the scope's front panel controls until I got a display. It was very dim and later I found the rear panel brightness pot and cranked it up all the way, as will be seen in the last photo below. It seems the "audio" mode display is a bit overblown and the front panel Level control doesn't do much - again likely dirty... well I hope so!
So The scope of the job is a cleaning, total recap, convert dial to LED along with the dial pointer and all adjustments. I also have to locate a pushbutton cap, a regular knob and deal with the broken off balance control. The one bummer is the damage on the upper edge of the raised bezel. I have had some sucess before repairing these so will give it a shot.
This will be my first 2500 so come along and learn with me while I go!
