Marantz 250M rebuild by Bob Speece
Discussion in 'Marantz Audio' started by airtime, Mar 22, 2017.
  1. airtime
    airtime Super Member
    2,209
    Central Arizona
    I wanted to post this for a while now. Bob did an amazing job on this jewel of an amp. And BTW it sounds every bit as good as my coveted Latino ST-70 tube amp.
    If I miss a step I hope Bob jumps in and adds to it.
    First old caps out and heat sinks removed
    All the old heatsink compound and mica insulators removed and heatsinks cleaned up...
    Newmain filter caps on the left with the old original caps on the right
    Over the last several days I have finished the relay protection board and the left amp board.
    Before....
    After
    This is a list of some of the things Bob did as well.
    I replaced the drivers with new correctly matched 2SC783 and 2SA483's with new mica insulators and Dow 340 heatsink compound making sure that the small nylon spacers were in place.
    I replaced the predrivers with new matched ST 2N3440 and 2N5416's.
    I replaced the differential input pair with matched and heatshrink bonded MPS6519's.
    Used Vishay AML138 for the axial caps and a Panasonic FC for the 100uf tantalum C527.
    Tomorrow I plan on working on the right channel amp board with the same treatment.
    Those oem original type Toshiba TO66 and ST 3440/5416 transistors are rare and hard to source but they are the best and look far better than shoehorning in some TO220's like others do.
    pics of the flyback diodes mod that is detailed in Service Bulletin M-250-3.
    I have the new OnSemi MJE21195/96 output transistors installed on their heatsinks with new mica insulators and Dow 340 heatsink compound.
    Both new 24,000uf 100v main filter caps are in ,along with their Panasonic 2.2uf poly film bypass caps....
    New LED lamps using Don Haywood's premium lamps.....
  2. mcheinstein
    mcheinstein New Member
    16
    Looks beautiful, Airtime. Thanks again for helping me out in my thread on the 1200. I'll be following this one!
    KutzlerTrans likes this.
  3. KutzlerTrans
    KutzlerTrans Jennie & I with Buddy and Barney. Subscriber
    2,988
    Wisconsin
    Mr Bob is one of the Best :thumbsup:
    Congrats on the unit. Now you can blow the doors off of the place.:jump:
  4. Steven Tate
    3,013
    N. Richland Hills, TX
    Fantastic looking unit! I'm sure Bob has that thing ready to crank it up for many years to come. :thumbsup:
  5. airtime
    2,209
    Central Arizona
    I didn't want to get into an audio review as much as point out the detail that Bob did restoring this beauty.
    However sonically speaking it's awesome sounding. Honestly I wasn't expecting it to sound as good as it does. Now I look forward to using it in the rotation even against my tube amps.
    catrafter, SWL3600 and Trojan4Life like this.
  6. SWL3600
    SWL3600 AK Subscriber Subscriber
    1,541
    Twin Lakes, WI
    Awesome. I'm looking forward to Bob restoring my 250 this fall. Can't wait! :)
  7. audiobeer
    audiobeer AK Subscriber Subscriber
    562
    St. Peters, Mo.
    I wish I had room to list all the items Bob has restored for me. He’s rebuilding my Marantz 4400 and has a 250M and 33 Preamp he’s getting together for me. He’s “The Man” when it comes to Vintage equipment!
    SWL3600 likes this.
  8. Steven Tate
    3,013
    Agree 100% :thumbsup:
  9. txturbo
    txturbo AK Subscriber Subscriber
    930
    Austin, TX
    Really nice! I am a sucker for the blue PCB's.
  10. airtime
    2,209
    Central Arizona
    I'm listening to it RIGHT NOW. It's STILL a wow feeling when I turn it on
    SWL3600 likes this.
  11. airtime
    2,209
    Central Arizona
    For years I've been trying to like my NAD C275BEE power amp. But every time I plug it in and go back to the 250M I relearn what a jewel the 250M is. So once again the NAD will sit in the closet for another few years
    This NAD amp is about 8 years old and has less than 200 hours on it. Why use it when I the 250, VTA ST-70 and Sherwood.
  12. SWL3600
    1,541
    Twin Lakes, WI
    Yer killin me....:)
  13. SWL3600
    1,541
    Twin Lakes, WI
    Until my 250 goes to Bob for repair/restoration.....I've been using my restored 3300/1200b combo. I know the preamp in the 1200b is essentially a 3300 but after comparing both scenarios, for some reason using the separate 3300 pre sounds better.
    I'm anxious/curious to hear the difference in performance....if any....when I get the 250 back and compare it to the 1200b. In the meantime I absolutely dig the 1200b.
  14. airtime
    2,209
    Central Arizona
    The 3300 is a wonderful match for the 250.
    You're gonna be VERY happy with that 250 rebuild
    SWL3600 likes this.
  15. audiobeer
    562
    St. Peters, Mo.
    Well I got it back and works like a new one would. Anyone that says it is a sacrilege to make it black must know it’s easy to make it go back! Thanks again Bob Speece, I couldn’t be happier unless of course you delivered it with Beer and Pizza!
    Loner, SWL3600, Steven Tate and 3 others like this.
  16. JediDude
    JediDude Active Member
    196
    Ottawa, Ontario
    Looks good.... ;-})>
  17. Bkphoto
    Bkphoto Super Member
    1,761
    Westchester, NY
    He did mine also...!
  18. Pete B
    Pete B AK Member Subscriber
    1,993
    CT, USA
    Those new PSU caps look like, but I have to check the dimensions to be sure:
    Cornell-Dubilier DCM243U100DC2B
    I have one of these that needs a recap.
  19. airtime
    2,209
    Central Arizona
    Contact Bob for the exact part number.
    As I've already posted it sounds AMAZING
  20. wlhd1610
    wlhd1610 Penny and her new friend Sponsor Subscriber
    2,694
    Catskill NY
    Thanks for all the kind words guys.
    This is the cap I use:
    DigiKey 565-3679-ND
    24,000uf 100V screw terminal fits perfectly in existing brackets.
    Bob
    Finnetric and Pete B like this.
