Proud Vet
Member
The only inputs I have open on my pre amp is the mic, phono 2 and Aux 2. In my tuner input of the preamp ( marantz 3300) I have a Fanfare FT-1A tuner and like to have my Marantz 2238B receiver tuner section to play through the system as well at different times of course. Yes I have an roof top antenna on an a/b switch placed into both the FT-1A tuner and the receiver ( 2238B ). What input if any of the 3 that I have available on my pre amp for the tuner section of the 2238b to be played through my system if all possible. BTW no inputs or outputs are being used on the 2238b. Had the 2238b sitting idle in the system not being used other than the powering up in the system. Was using the fm section on the 2238B as my tuner only prior to adding the Fanfare Tuner placed into the tuner inputs of the pre amp. Thanks ahead of time for any replies if all possible it can be accomplished.
Proud Veteran
Proud Veteran
